Hello Guest it is June 12, 2026, 04:51:45 PM
Author Topic: PWM analogue 0-10V need help  (Read 10648 times)
« on: May 03, 2012, 02:58:44 PM »
Hi all again,
I got no reply to my previous post so I thought I'd try again.....
I'm in the process of wiring my VFD to Mach via C32 bob from CNC4PC.....but at present I've not been able to progress, while I am registering 2.5V on my multi-meter at the VFD analogue 0-10V terminals when I enter an M3 comand in MDI and respectively an M5 will switch off the voltage reading on the meter, at least I'm doing something correct.....but no matter what settings I input into Mach3 regarding pulley ratios max speed PWM % increase I cannot increas this analogue voltage reading from 2.5V to 10V, so therefore I will only get 25% of the max speed when I connect my VFD.....
I'd really appreciate advice here guy's, how or where am I inputting incorrect info..???
______________________________
Eoin
  •  9,356 9,356
Re: PWM analogue 0-10V need help
« Reply #1 on: May 04, 2012, 04:50:36 AM »
Hi Mad Welder,
Just a snip from the C32 manual - "Requirements: It requires a +12VDC@50mA power supply to operate".
Don't know if this helps but it was just a thought.
« Reply #2 on: May 04, 2012, 05:44:52 AM »
Many thanks for the reply, and yup I've the 12VDC PSU connected to the X1 terminal of the C32 bob.......
and I've just sorted the problem it was a bit of a head scratcher for me as I'm unfamiliar with this whole electronics and software setup but in the SS plugin config window I inputted a check in the Step and Dir box as opposed to the PWM.....
Eoin
  •  9,356 9,356
« Reply #3 on: May 04, 2012, 06:10:26 AM »
I am pleased you got it sorted.  :)  (more pictures required of the excellent things you make, please - that Epiphone is great).
