Hello Guest it is June 11, 2026, 08:41:42 AM
Author Topic: Is there a way...  (Read 10634 times)
Offline SScnc
  •  77 77
Is there a way...
« on: March 31, 2012, 04:51:56 PM »
Is it possible to bring in sensor inputs from something like a proximity switch on the pokeys?
Offline NeoTO
  •  504 504
    • PoLabs
Re: Is there a way...
« Reply #1 on: April 02, 2012, 01:24:17 AM »
What kind of output does this switch have?
If it has an analog output use the appropriate voltage attenuator first and connect it to the analog input pin (PoKeys has the limit of max. 3.3V on those pins).
If the switch has 4-20mA current output, use an appropriate resistor and connect it to the analog input pin similarly as above.
Give more details on the proximity switch to help you further.
Matevž, PoLabs
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
« Reply #2 on: April 03, 2012, 08:52:25 PM »
Prox's usually run at 24vdc (sinking or sourcing), to interface to the PK, you could
do it through a Solid state relay, or if speed not real important, a standard relay.
Scott
