May 28, 2012, 10:51:42 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Mach/Integration/Hardware
Pages: 1   Go Down
Print
Author Topic: Mach/Integration/Hardware  (Read 126 times)
ducati
Active Member
Offline Offline
View Profile
« on: January 18, 2012, 08:26:29 AM »
 Smiley
I would like to pass along my experiences converting my  3 axis knee mill.
I converted the mill from a early 90's Southwestern Industries package that ran the OS from a floppy and loaded all the programs by floppy. Now I am running Mach Mill, have a great interface control box that can be customized to my liking.
I was very fortunate to find a member here SS Systems  Scott (Poppabear) Shafer that has guided thru the selection and purchase of  hardware, software configurations and developed software to enhance the project. While I am not new to machining and have installed some "factory" kits on mills at work, this proved to be a steeper learning curve than I first estimated. My hardware was purchased from CNC4PC  (Arturo Duncan).   As with many new projects there are ALWAYS rocks in the path to success.  Most of the rocks in my road were created by my level of inexperience but were solved by Scott and Arturo.  Scott developed a plugin to enhance my MPG and allow me to use a hand held switch for Feed/Pause  control. I had a hand held switch setup at work and was comfortable using it. The plugin for the pendant Scott developed installed and works flawlessly.Now I have a mill setup exactly as I wanted, with all the bells and whistles(for now) that will allow me to create the projects I could not have done with the old system.
Mach software, CNC4PC hardware and the infinite patience of Scott Shafer have allowed me to breath new and improved life into my old mill.
Now it is time to model up some parts and enjoy the new setup.
Tweakie.CNC
Active Member
Online Online
Super Kitty.
View Profile WWW
« Reply #1 on: January 18, 2012, 08:54:15 AM »
And post a few pictures of the things you make with it perhaps ??  Grin
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
ducati
Active Member
Offline Offline
View Profile
« Reply #2 on: January 18, 2012, 09:00:42 AM »
Be glad to show a few parts in hopefully the next few weeks.
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline Offline
Briceville, TN, USA
View Profile WWW
« Reply #3 on: January 18, 2012, 12:33:48 PM »
Wow!!  Thank you for the nice Chops Ken!! I too and looking forward to seeing your mill in action! (or pics).
Scott
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, PLCs, Macros, ATC's, machine build, retrofit and Prototyping
http://sites.google.com/site/volunteerfablab/
Pages: 1   Go Up
Print
Jump to:
