Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 28, 2012, 10:47:38 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Homing and limit troubles....
Pages:
1
Go Down
« previous
next »
Author
Topic: Homing and limit troubles.... (Read 250 times)
peterm
Active Member
Offline
on:
January 16, 2012, 02:01:39 AM »
Finally got my X and Y switches hooked up (still waiting for my Z switches) but having some issues.
First let me explain my setup. I have 2 switches per axis and each switch is supposed to act as a Home and Limit switch.
If jog away from the switches and then press "goto zero" and sometimes it goes to zero as suppose to. It slows down but never touches the switch, other times it engages the switch and triggers the limit and never backs off the switch. Not sure exactly what to do.
Do I jog the machine to the zero position and press "ref all"? and then mach3 knows thats home? How do I set it up so it can find home and back off the switch and then save that setting? I'm sure I'm doing something wrong. I've watch the videos but still confused.
Any help would be great! Thanks...
Active Member
Offline
Carnoustie, Scotland
Re: Homing and limit troubles....
Reply #1 on:
January 16, 2012, 03:10:40 AM »
If you have the switches set as both home and limits then it should work fine. You press Ref All from any place and the axis should move in turn to the switch, hit it then reverse and stop again when the switch closes, that is then set as the home position in Mach. Make sure you have auto zero chosen in the Homing and Limits setup (from Config menu)
Go to Zero is telling Mach to go to the current offset zero and not necessarily the home position, it will depend on whether you have set an offset or not.
peterm
Active Member
Offline
Reply #2 on:
January 16, 2012, 11:30:08 AM »
Thanks Hood. Unfortunate pressing Ref All doesn't do anything...
Active Member
Offline
Reply #3 on:
January 16, 2012, 11:46:29 AM »
If you attach your xml I will have a look and see what the problem is.
peterm
Active Member
Offline
Reply #4 on:
January 16, 2012, 02:11:38 PM »
Thanks hood, I'll get it tonight.
How do I get the XML file?
Active Member
Offline
Reply #5 on:
January 16, 2012, 02:16:30 PM »
Look lower left of Mach screen to see the name of the profile you are using, assuming you are not sure, then go to the Mach3 folder and find a file with that name and a xml extension. You will likely have to rename before the forum will accept so just copy to your desktop and renema to something like peterm.xml
peterm
Active Member
Offline
Reply #6 on:
January 16, 2012, 10:15:21 PM »
Here you go. Thanks a lot!
peterm.xml
(148.43 KB - downloaded 26 times.)
Active Member
Offline
Reply #7 on:
January 17, 2012, 03:05:34 AM »
You have the switches set as limits but you have not set up them as home switches. What you want to do is go to Config menu then Ports and Pins then Inputs and set the Home for each axis up. If you want to home to the fully negative then set X and Y Home switch to same port number as your X and Y negative limits. If you want to home to the positive switch then set that as your Home switch and then put in the distance you are away from fully negative in the Home Off box.
peterm
Active Member
Offline
Reply #8 on:
January 17, 2012, 09:43:31 PM »
I might have missed something!! Thanks so much for taking a look! I'll get on it tonight
peterm
Active Member
Offline
Reply #9 on:
January 18, 2012, 01:06:19 AM »
Hood, it worked!!
thanks so much!
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
