Hello Guest it is June 10, 2026, 09:15:51 AM
Author Topic: Locked Feed rate  (Read 7942 times)
Locked Feed rate
« on: January 02, 2012, 08:53:59 PM »
A friend contacted me about a problem he created in Mach3.  He said his Feed Rate is locked at 2.3 and the over ride button flashes.  I have tried to come up with ideas of what may have happened but am at a loss.
Anyone have any ideas of where to look?
Russ
Re: Locked Feed rate
« Reply #1 on: January 02, 2012, 09:00:18 PM »
Post the xml file he is using and someone will have a look and see what's up.
« Reply #2 on: January 03, 2012, 09:10:31 PM »
I am waiting for a copy of the xml file and will post.  Hopefully tomorrow.
Russ
« Reply #3 on: January 19, 2012, 07:37:22 AM »
I never heard back from the friend and finally had a chance to go see him Monday.  His problem was simply a bad feed rate in the cut file.  I edited the file and told him how to correct it in his source and everything is fine.  His inexperience caused a lot of unnecessary questions.
Russ
