Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 28, 2012, 09:42:52 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Machine Limits without limit switches? to stop me crashing
Pages:
1
Go Down
« previous
next »
Author
Topic: Machine Limits without limit switches? to stop me crashing (Read 356 times)
CHCChrisA
Active Member
Offline
on:
December 27, 2011, 04:28:50 PM »
Hi Guys
I am new to this, I have watched the video on homing and limits but its talking about the use of limit switches and i dont have limit switches, i am sorry if this question has been asked a thousand times, i have been searching for a while and playing round in Mach 3, i just want to understand how to set up limits without limit swithces so it doesnt crash into the ends?
Chris
Active Member
Online
Carnoustie, Scotland
Re: Machine Limits without limit switches? to stop me crashing
Reply #1 on:
December 27, 2011, 04:43:13 PM »
Jog each axis to its extent (X and Y fully negative, Z fully positive). Then press Ref All button. That should zero the machine coordinates. You can then go to Config menu and then Homing and limits and set up soft limits. The values you enter there will be 0 for X and Y min and Z Max and whatever your travel is for X, Y and Z, Z being a negative value. Then make sure Soft Limits are enabled on the main screen of Mach and you should not be able t jog to the end of the axis. You may have to adjust the Slow Zone distance if it does not slow down fast enough when jogging at full rapid.
CHCChrisA
Active Member
Offline
Reply #2 on:
December 27, 2011, 05:05:26 PM »
Thanks hood, I will go try it out
Global Moderator
Offline
Reply #3 on:
December 28, 2011, 06:27:41 AM »
See the following In Members Doc's
http://www.machsupport.com/forum/index.php/topic,11409.msg72346.html#msg72346
titchener
Active Member
Offline
Reply #4 on:
December 28, 2011, 12:50:38 PM »
To be fully candid, you can't really count on Mach's software based limits to keep you from hitting your physical end limits, there's just too many ways for those limits to get mis-set or ignored.
Its not that hard to put physical limit switches on your machine, take the time to do that, it will definetly pay in the long run.
Get lever switches that are normally closed and wire then in a loop from switch to switch. This way if any of your wiring or connections fail you know right away and failure doesn't disable your limit switch system. This is also the easiest limit system to setup and its simplicity has advantages.
Lever switches are cheap and easy to mount and get set up, just machine some small blocks that mount on the other surface that actuate the levers.
Paul T.
CHCChrisA
Active Member
Offline
Reply #5 on:
December 28, 2011, 08:31:47 PM »
Thanks guys, i will look into limit switches.
Another silly question i have is,
I have everything set and homed, now if i move the gantry up to the material and zero it out and run the gcode, when its finished and i hit return to zero it returns to where i zero'd it out not to the home back in its corner, the only way i can get it to do it is to close the program and open it again and the hit return to zero and it goes back to its corner?
i am sure its something simple i am missing
Chris
Active Member
Online
Reply #6 on:
December 29, 2011, 01:53:09 AM »
That is normal, the Go To Zero is for offset Zero and that is what you have set up by zeroing out the axis. If you want to move to machine zero then you would either have to call it in code, MDI or make a button to do it.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
