Hello Guest it is June 12, 2026, 05:21:01 AM
Author Topic: problem with pci express  (Read 22184 times)
« on: December 24, 2011, 02:23:48 PM »
hi guys
first see this
Code: [Select]
www.youtube.com/watch?v=nncvO3ZgguM
(and don't say to me laptop cant run mach3)
I bought a pci express tp lpt convertor for my laptop
and my problem is how i can Declare my port to mach3?
and read this to understand me:
Code: [Select]
www.easy-cnc.com/web/download/QuickStartMach3.pdfbut my port in device manager isn't like that PDF:
Code: [Select]
http://up6.iranblog.com/images/cg3r6ig3ec1bpbgf0291.jpgso how i can config my port in mach3?
i will be Grateful for your helps
thanx
Re: problem with pci express
« Reply #1 on: December 24, 2011, 02:57:18 PM »
Your pic shows a screenshot of a USB device, that is not the parallel port, or if it is, then it is a USB to parallel adapter you have and I dont think that will work.
Now regarding a laptop, some work, some dont, modern ones with their power saving are more likely not to work.
« Reply #2 on: December 25, 2011, 06:34:40 AM »
thank u for your ansewer my friend
but its my express card (express cards send and receive in with serial )
so the laptop know them as usb
but if u saw the video you saw he express card
« Reply #3 on: December 25, 2011, 07:08:11 AM »
It must show up as an LPT port in device manager to get the port address. If it only appears as a USB port, then it won't work.
« Reply #4 on: December 25, 2011, 10:48:17 AM »
thanx for your help
but if u see the video u will see express card
so what i must do?
« Reply #5 on: December 25, 2011, 01:27:31 PM »
That appears to be an express pcie card for laptops they are very similar to the old pcmcia cards in that they can replicate a LPT port exactly.
To do that they use a driver to imulate the lpt and must be called AS an lpt .
I would assume that once the driver is installed the PC should see it as a lpt port???
What does the device manager show it as ???? what is its address?
SO do you have the driver installed ?
« Reply #6 on: December 25, 2011, 01:29:08 PM »
thanx for your answer
no it doesn't need t install driver
am i must install driver?
« Last Edit: December 25, 2011, 01:35:26 PM by shs_micro2 »
« Reply #7 on: December 25, 2011, 01:55:56 PM »
What does it show up as in Device Manager???
All devcies use a driver in windows some just install as you plug them in.
« Reply #8 on: December 25, 2011, 02:04:04 PM »
it show up like usb:
and i understand what is the problem
look at this page :
http://www.cooldrives.com/1ppaspex34.html
my card is like this:http://www.cooldrives.com/express-card-laptop-lpt-port.html
and the problem is:
Please Note: This item does not Require any Drivers it is not a Hardware LPT port it is a USB LPT Supporting Emulator, it will work with Standard Printers only. No Dongles, No Programmers, No Hasps, No Scanners, Not True LPT Support only Printing Support.
« Reply #9 on: December 25, 2011, 02:58:49 PM »
Looks like you have your answer. You r card is NOT like his card.
