May 28, 2012, 09:39:20 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Help !!..New to CNC .. KX3 question and mach3
Pages: 1   Go Down
Print
Author Topic: Help !!..New to CNC .. KX3 question and mach3  (Read 197 times)
zoe
Active Member
Offline Offline
View Profile
« on: December 24, 2011, 10:11:01 AM »
Hello all...
 This is my first post. I am new to CNC and just purchased a sieg KX3 and have a question. Is it possible to use Mach3 with the Sieg KX3 that has a Cat5 interface instead of the parallel port. If so how do I go about it. I have google and searched everything I know. Thank you for any help in advance
Zoe
jeremy0203
Active Member
Offline Offline
View Profile
« Reply #1 on: December 24, 2011, 10:53:32 AM »
check out the ethernet version of the smoothstepper.
zoe
Active Member
Offline Offline
View Profile
« Reply #2 on: December 24, 2011, 10:57:15 AM »
Thank you... Should i just google search and download ? I appreciate your help.. thank you
zoe
Active Member
Offline Offline
View Profile
« Reply #3 on: December 24, 2011, 10:58:10 AM »
oh I see it is hardware.. I will look into it..
Pages: 1   Go Up
Print
Jump to:
