Hello Guest it is June 12, 2026, 06:23:41 PM
Author Topic: Delta VFD control from Mach  (Read 20793 times)
« on: November 03, 2011, 08:44:59 AM »
I have a Delta VFD022B21A that I want to control from Mach3.
What do I need?
Any one know what I can get the remote control for this unit?
Don Williams
  •  9,356 9,356
Re: Delta VFD control from Mach
« Reply #1 on: November 03, 2011, 11:11:25 AM »
Hi Don,
Welcome to the forum.
The VFD requires a 0 - 10 Volt dc source to control the speed and Mach has a PWM output intended for operating a VFD.
You need a controller board to convert the PWM signal to the 0 - 10V such as this http://www.cnc4pc.com/Store/osc/product_info.php?cPath=25&products_id=303 which also has the on/off - forward/reverse relays.
« Reply #2 on: November 03, 2011, 12:17:35 PM »
« Reply #3 on: November 03, 2011, 02:54:08 PM »
Thanks guys! The more I learn about this stuff the more I find that  I don't know:)
Don
  •  9,356 9,356
« Reply #4 on: November 04, 2011, 02:16:26 AM »
Don
Tell me about it  ;D
« Reply #5 on: November 04, 2011, 02:51:30 AM »
Hi Don
Have you see my VSC?
If you wont I give you the schematic to build yourself.
If you wont to see it this is my web www.robotfactory.it
Andrea
« Last Edit: November 04, 2011, 03:03:51 AM by robotmar »
« Reply #6 on: December 01, 2011, 08:12:37 AM »
The C41 has two relays with the connectors labeled NO V_IN NC.  Will the V_IN connect to 24V from the VFD?  Then the NO connectors connect to FWD/REV?
Don
« Reply #7 on: December 01, 2011, 09:51:48 AM »
Hi Don
Andrea
Hi Andrea, I would be interested in the schematic, if possible.
« Reply #8 on: December 01, 2011, 09:52:32 AM »
  •  9,356 9,356
« Reply #9 on: December 01, 2011, 10:08:33 AM »
Hi Don,
You need to check with your VFD instructions but selecting US Mode on the C41,  I would connect both V-IN together and connect these to VFD terminal SD   then relay #1 terminal NO to VFD terminal STF   and relay #2 terminal NO to VFD terminal STR.
