Hello Guest it is June 12, 2026, 01:46:10 PM
Author Topic: Cannot run DriverTest.exe as unpriviledged user  (Read 15736 times)
« on: November 01, 2011, 10:30:42 AM »
Hello,
I recently installed the Mach 3 software on a 32-bit Windows XP SP3 system. I am able to run the DriverTest.exe application as an administrative user and the test passes successfully. When unprivileged users of the system attempt to run DriverTest.exe nothing happens. Are there any known issues with this? Are there any log files I could check to see what is going on?
Thank you very much in advance,
Kyle
Re: Cannot run DriverTest.exe as unpriviledged user
« Reply #1 on: November 01, 2011, 10:45:46 AM »
That is a windows permissions problem. Either set MACH3 up to run as normal OR give the users permissions.
« Reply #2 on: November 01, 2011, 11:15:35 AM »
I have given users full control to the C:\Mach3 folder. What else should the users have permissions to?
« Reply #3 on: November 01, 2011, 11:49:40 AM »
IF "you as admin" can run it from the Dir and they can't then you did not clear up the permissions issues.  I have seen this many times in the past and present with windows( Vista being the worse so far).
DO I have the answer NO, I am not a windows guru(;-)
IS this on a single seperate computer used to ONLY run the machine?
Or does it do OTHER functions as well?? Networked??
« Last Edit: November 01, 2011, 11:53:09 AM by BR549 »
« Reply #4 on: November 01, 2011, 11:54:56 AM »
The machine is on a windows domain, but its sole purpose in life is to run this software/hardware.
« Reply #5 on: November 01, 2011, 11:57:08 AM »
Does that mean networked ???
« Reply #6 on: November 01, 2011, 11:57:39 AM »
Yes the computer is connected to a network. Sorry.
« Reply #7 on: November 01, 2011, 12:34:34 PM »
« Reply #8 on: November 01, 2011, 12:58:17 PM »
Thanks TP. The computer is connected to a network, but the Mach 3 software was all installed to the local hard drive. I have given the Users group Full Control the the entire Mach 3 directory and verified that Users are able to read write and execute to files within the Mach 3 directory.
Is there any type of a log file that is created when the DriverTest.exe application is run? I would be able to fix the problem if I could just find a clue. Currently if I double click on the DriverTest.exe application no process is created in the task manager and nothing happens at all.
« Reply #9 on: November 01, 2011, 02:23:11 PM »
Can you right click and double check the properties and permissions??
Just a thought, (;-) TP
