Hello Guest it is June 11, 2026, 03:42:25 AM
Author Topic: Studs welding  (Read 34916 times)
Studs welding
« on: October 31, 2011, 09:27:23 AM »
Hi
A new customization using Mach3.
This is a machine for studs welding with capacitive discharge, note also the interface used for Mach3.
http://www.youtube.com/watch?v=mx2yd1OJ54U
In addition to this video, many other interesting video of working with my machine and of course Mach3...
Andrea
  •  9,356 9,356
Re: Studs welding
« Reply #1 on: October 31, 2011, 11:08:41 AM »
Excellent Andrea.
Did you design the head/nose that actually holds the studs or is this a proprietary device ??
Re: Studs welding
« Reply #2 on: October 31, 2011, 11:50:03 AM »
You never cease to amaze me Andrea!!  Great work-
Re: Studs welding
« Reply #3 on: October 31, 2011, 04:59:55 PM »
Good job Andrea!!  I like the flip down cover.  That will help keep it nice.  You and Tweakie have all the cool toys!   :)
Re: Studs welding
« Reply #4 on: November 01, 2011, 03:46:48 AM »
Hi Tweakie
Yes, the head/nose that actually holds the studs is a proprietary device...
Have you see on my web the VSC (Variable Speed Control), how do you think?
Andrea
  •  9,356 9,356
Re: Studs welding
« Reply #5 on: November 01, 2011, 05:42:48 AM »
Hi Andrea,
I like your new VSC - it is very neat - (why is your equipment wiring always so neat and tidy ??  ;D ).
I have been working on a, perhaps, similar device to control laser power from (a spare axis) step and direction signals in order to get away from the Mach PWM output which conflicts with the Impact / Laser plugin operation. I never thought of using the LM331 as I seem to do everything these days with the Microchip PIC controllers.
Keep up the excellent work, your website is a real inspiration.
Re: Studs welding
« Reply #6 on: November 03, 2011, 06:37:07 AM »
Hi
Due to the demand, I decided to make available the screen, the macro and the post (SheetCam TNG) that I used.
You can use a screen with a touchscreen display, because the buttons are sufficiently large.
The screen was carried out starting from the Gerry screen "3 Axis Router Screen"
http://www.machsupport.com/screens.php
Thanks Gerry.
In the "Settings" screen, there are two fields that are identified with "Welding" used by the macro.
Pause  = OemCode 1006
Pause after welding...
Offset = OemCode 1005
Thickness of the part used for zero Z...
In addition to a hidden button for calibration of axes, the word "Stud position" is the button.
The button "EXIT PROGRAM" is a macro that shutdown Mach3, useful for touchscreen displays.
In the "Run Machine" screen, the button "Laser Goto Zero" is a macro that reads the two offset values.
The values must be set with reference to the offset between the tool and the laser.
The button "PARK" is a macro that position the head close to machine zero point, parked just before the shutdown.
In the "Load Programs" screen, the button "Keyboard" is a macro that starts an on-screen virtual keyboard.
See the excellent program  "Click-N-Type"
http://cnt.lakefolks.com/
I hope that this information can be useful to many people
Andrea
Sorry for my bad English, I hope I never say the wrong things.
Re: Studs welding
« Reply #7 on: November 06, 2011, 04:26:25 AM »
Hi
Attention!!!
I did not remember to emphasize that all values ​​of the macros are in millimeters...
Andrea
