Hello Guest it is June 11, 2026, 03:40:14 AM
Author Topic: lcd getting HOT  (Read 16222 times)
Offline Bill_O
  •  611 611
lcd getting HOT
« on: October 31, 2011, 07:59:28 AM »
i purchased an AND481GST lcd to hook up to my pokeys55
with only the 5v and the ground connected one of the chips on the back gets very hot very fast
when i had everything hooked up it did not work
any ideas?
bill
Offline borisz
  •  220 220
    • www.poscope.com
Re: lcd getting HOT
« Reply #1 on: November 01, 2011, 05:11:46 PM »
LCD chips should not be hot.
Please check LCD connection. Probably LCD is not OK.
We checked many types of LCDs and most of them are work without any problems.
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
Re: lcd getting HOT
« Reply #2 on: November 01, 2011, 05:18:42 PM »
Hi Borisz.
You mentioned "most" LCD's are ok, do you have a list of those that aren't?
Offline borisz
  •  220 220
    • www.poscope.com
Re: lcd getting HOT
« Reply #3 on: November 01, 2011, 05:29:45 PM »
There was one or two refurbished LCDs which I cannot remember make and model or they was not visible.
Offline Bill_O
  •  611 611
Re: lcd getting HOT
« Reply #4 on: November 02, 2011, 04:39:26 PM »
borisz,
they use a HD44780 microcontroler
i thought they were supposed to work.
bill
Offline borisz
  •  220 220
    • www.poscope.com
Re: lcd getting HOT
« Reply #5 on: November 03, 2011, 02:17:38 AM »
Iz should work iit has HD44780 controller. But if it is hot, probably you did not connected it OK and/or it is broken.
Offline NeoTO
  •  504 504
    • PoLabs
Re: lcd getting HOT
« Reply #6 on: November 04, 2011, 02:26:21 AM »
Did you pay attention to the AND481GST LCD pinout? According to the datasheet, the pinout is not fully compatible to other HD44780 displays. Namely, the +5V is on pin 1 and GND on pin2 (usually, HD44780 displays have these two pins the other way around).
Offline Bill_O
  •  611 611
Re: lcd getting HOT
« Reply #7 on: November 23, 2011, 06:59:00 AM »
NeoTO,
the pinout i had showed the 5v on pin 2 and the ground on pin 1
i will flip them and see what happens
thanks
bill
