Hello Guest it is June 11, 2026, 07:25:30 AM
Author Topic: Looking for angles on single lip cutters  (Read 8074 times)
« on: September 25, 2011, 12:01:32 PM »
OK, I finally purchased a cutter grinder. I think the instructions were translated from japaneese to chineese to english. What I'm trying to figure out are the actual angles of a single lip cutter. I primarily use 30deg cutters with .005 tips. What I'd like to know specifically is the angle of the tip itself and the clearance or back angle of the cutter. Any info is certainly appreciated! Thanks, Mike
  •  9,356 9,356
Re: Looking for angles on single lip cutters
« Reply #1 on: September 26, 2011, 02:32:23 AM »
Hi Mike,
This web-page should have all the details you require   http://www.majosoft.com/engraving/html/anatomy_of_an_engraving_cutter.htm
Including the data from the Antares site  http://www.antaresinc.net/FactROT.html
« Last Edit: September 26, 2011, 02:38:56 AM by Tweakie.CNC »
« Reply #2 on: September 27, 2011, 07:37:26 AM »
Definately good info. I'm looking for specific numbers though.
