Hello Guest it is June 10, 2026, 08:22:28 AM
Author Topic: Z axis brake releases to quickly on reset.  (Read 19802 times)
Re: Z axis brake releases to quickly on reset.
« Reply #10 on: September 10, 2011, 07:03:40 PM »
$20-30 over here for a simple delay on relay.
« Reply #11 on: September 10, 2011, 07:11:24 PM »
We are about that price but its £ so about 1/3 as much again as you.
Edit just checked conversion and its worse than I thought ;D £20 to £30 would be $32 to $48 ;D
« Last Edit: September 10, 2011, 07:17:03 PM by Hood »
« Reply #12 on: September 10, 2011, 08:38:58 PM »
WOW I guess you have to add the VAT as well ??
« Reply #13 on: September 11, 2011, 03:37:51 AM »
Yes, only 20% ;D
« Reply #14 on: September 11, 2011, 04:25:43 AM »
first off
I am presuming your using servo drives? If they are Industrial end drives often they will have brake relays built in and often they can be set up with delays, I know mine can be so may be worth investigating if yours can as it would be the simplest and most robust option.
« Reply #15 on: September 11, 2011, 02:18:14 PM »
Hey BR549, The delay relay is a great idea and i did some exploring online. I did not see anything in the $20 or $30 range. Do you know of one? I can relay the power supply itself with the 120 vac input or relay the 24 vdc output. The brake pulls less then 1 amp.
« Reply #16 on: September 11, 2011, 02:46:08 PM »
Grainger online catalog search for time delay relay. Low as $15.00
« Reply #17 on: September 11, 2011, 04:23:36 PM »
BR549, you are right. There are a couple that will work perfectly in the Grainger catalogue. For the benefit of others that may have the same problem I am going to use a Dayton #2A561. Thanks for your help.
Russ
