Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 28, 2012, 01:26:28 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
ERRATIC BEHAVIOR
Pages:
1
Go Down
« previous
next »
Author
Topic: ERRATIC BEHAVIOR (Read 242 times)
mike bush
Active Member
Offline
ERRATIC BEHAVIOR
on:
August 27, 2011, 06:57:17 PM »
Afternoon folk, a friend and I built a 4 axis machine a few years ago and it has worked pretty well. Naturally when we needed something on a dead line the machine decided to test our patience.
The original computer died. So we replaced that. Then we decided to upgrade the Sound logic break out board, which never gave us a problem, to the new model that would allow spindle speed control through the VFD.
The behavior now is that the z-axis is erratic. If I press the + key it may move + or it may move -. When pressed again it may move + or -. It also makes an unpleasant sound . We have tried to trouble shoot the problem.. We swapped the misbehaving cable from Z to Y, and we switched them at the motor end and the behavior stayed with the third channel (Z) . So we know the motor is good, and the cable is good,. I've swapped the leads from the breakout board, z=y &y=z, to the mil-spec plugs that the cables connect to and the problem stayed with the 3rd (Z) channel. I've gone over the wiring with an ohm meter and it all seems good. I swapped the gecko for a new one. I swapped the computer to a known good one. Swapped the breakout board to the old one that always worked fine. Running out of things to blame I went from Parallel Port control to Smooth stepper USB control and the behavior is still the same. Also when I watch the dir lights on the breakout board the light comes on when the + key is pressed and off when the - key is pressed but the axis will move erratically one way or the other. Seems to me that I have one way or another eliminated everything BUT it still doesn't work. I searched the site here and found a similar problem and the suggestion was that one stepper wire was bad but as I say all the cables and the wiring seem to be fine. I think I will up-grade Mach 3 but just out of desperation.
Any thoughts?
thanks
Mike
mike bush
Active Member
Offline
Re: ERRATIC BEHAVIOR
Reply #1 on:
August 27, 2011, 07:29:33 PM »
nevermind... As was said by the brain trust here before ...it has to be wiring. And it was ... bad milspec connector.
But it works now
thanks
Mike
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
