Hello Guest it is June 10, 2026, 08:19:50 PM
Author Topic: Vexta 5 phase stepper motor  (Read 16106 times)
« on: August 21, 2011, 09:14:25 AM »
Hi Lads
I am thinking about converting my 626 mill to cnc ,,,,, i have two un-used 5 phase steppers (PK596BW1-H100) and drivers (UDK5114NW2)  ,,, the motors have 100:1 harmonic drives and going off what info i can fined on them looks like they have a max shaft  rpm out put of 35 RPMS
newer model but close ,, step angle on the ones i have is 0.0072 deg
http://catalog.orientalmotor.com/item/stepping-motors--1068/pk-series-5-phase-stepping-motors/pk596be1-h100?&plpver=11&origin=advsrch&by=prod&filter=0&categid=1068&prodid=3001062
Do you think they would be suitable to use for the X,Y axis of the mill with 10 or 16 mm pitch ball screws ?
Thanks Rob
« Last Edit: August 21, 2011, 09:16:35 AM by RobWilson »
Re: Vexta 5 phase stepper motor
« Reply #1 on: August 21, 2011, 09:44:43 AM »
Will be extremely slow even with 16mm pitch, thats a max rapid of only 560mm/min, you would be looking for at least 4 or 5 times that speed.
Also the step count wuld be quite high, not sure if the drives are full/half or capable of microstepping but even at full step that would be 29KHz so if half stepping double that and so on.
« Reply #2 on: August 21, 2011, 09:51:49 AM »
Hi Hood
The driver dose have a half step setting ,,,,,,,, suppose i could go for 20mm pitch , that would give 700mm/pm rapid ,,, or use one for the Z axis and by two more for X and Y  :(
Rob
« Reply #3 on: August 21, 2011, 12:22:24 PM »
You would need a kernel of 60khz for that, some computers just wont be happy there so make sure you do a driver test at that frequency before investing money in ballscrews.
« Reply #4 on: August 21, 2011, 12:40:32 PM »
Just be in the shop and hooked  up a motor and driver for a test  to  the computer i use to run my Denford mill at 25KHz  set the steps/per to 20000 ,and to my surprise it actually ran , velocity was down to 40 per/min  :o    ,,,,,,,, stuck a taco on the motor shaft got 2800 rpms   ,,,,,,,,,, so that a very poor 28 rpms at the gear box end LOL
I think these motors would probably be better suited to a fourth axis ,,,,,,,,,, back to the drawing board  ;D
Rob
« Reply #5 on: August 23, 2011, 04:15:25 PM »
After giving up on the motors i have ,, now on ebay  ;)  ,,,,,,,,,,,,, what about this set http://www.zappautomation.co.uk/three-axis-driver-kit-with-stall-detect-p-520.html  ,(anyone interested in a Denford Starmill  lol ),, what would be a good size/pitch of ballscrews to go with 12Nm motor driving the screw direct ?.
Is the some sort of calculation for working out these things ?
Cheers  Rob
« Reply #6 on: August 23, 2011, 05:31:53 PM »
What size of mill is it as these are big steppers, I had 916ozin geared 2.5:1 on the Bridgeport and it was plenty, reckon I could probably have gone 1:1 with them.
5mm pitch screws are likely your best choice for a mill.
« Reply #7 on: August 23, 2011, 06:46:19 PM »
Some of the major manufactures have software which will calculate everything that you need and  even give you a list of applicable motors.
Remember that garbage in =garbage out..... ;)
« Reply #8 on: August 25, 2011, 10:59:13 AM »
Hi Hood ,,,,,,,,,,,,, the mill is a Chester 626 ,,,,,,I just thought BIGGER would be better  ;D  ,,, I was planning on fitting a stepper to  the knee and just locking off the quill .
Cheers Rich ,,,,,,,, i will have a look around the major manufactures sites
Rob
