Hello Guest it is June 10, 2026, 06:34:59 PM
Author Topic: Microstepping on the driver...  (Read 7866 times)
Offline Rikk
  •  19 19
« on: August 01, 2011, 11:21:06 AM »
If I change the micro step setting on the driver will I need to redo the steps per in mach3?  if so I assume if I say go from 16 to 8, I could divide the current number by 8 and that would be my new steps per?
                 ...........Rikk
Re: Microstepping on the driver...
« Reply #1 on: August 01, 2011, 11:38:09 AM »
yes you will need to change them
Offline ERP
  •  35 35
« Reply #2 on: August 01, 2011, 12:06:26 PM »
you would divide by 2 not 8 in that case but yes you will beed to change them
Offline Rikk
  •  19 19
« Reply #3 on: August 01, 2011, 12:30:58 PM »
I'll dive in and have a play then, see if this fixes my little issue :)
