Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 28, 2012, 12:14:36 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Re: Jogging & feedrate troubles (Mach 3 Mill)
Pages:
1
Go Down
« previous
next »
Author
Topic: Re: Jogging & feedrate troubles (Mach 3 Mill) (Read 325 times)
4ideas
Active Member
Offline
on:
July 26, 2011, 01:07:56 PM »
Hi all
Am a bit new to the CNC game and have recently aquired a large format machine that is not running quite as i want it to; maybe someone can assist please?
Subject line refers; yesterday after many restarts the machine was running at 6000mm\m and cutting long spline toolpaths (Cutting a 3D pattern) without any sweat or much jerking, today after the start I could not get it to do the same. Overriding the feed rate to 200% from a 2400 baseline shows the increased speed in the 'F' DRO, but this is not reflected in the actual speed DRO; it maxes out at between 600-800mm\m. I suspect it has to do with the CV Mode, but am not able to use the CV button on the program run screen; have looked under the settings screen but no luck so far; am I missing something obvious? I would like to get out of what seems to be the 'exact' cutting mode; am running a roughing program for a 3D pattern and accuracy is not that critical.
Any help would be greatly appreciated!
Active Member
Offline
Carnoustie, Scotland
Reply #1 on:
July 26, 2011, 01:10:57 PM »
4ideas
Can you attach your xml and the code you are running, you will need to either zip them or you will need to rename your xml before you can attach to the forum. To attach use the additional options button on the reply page.
4ideas
Active Member
Offline
Reply #2 on:
July 26, 2011, 01:27:57 PM »
Hi Hood
Zipped archive attached, thank you!
4ideas XML.zip
(3515.58 KB - downloaded 15 times.)
Active Member
Offline
Reply #3 on:
July 26, 2011, 01:32:57 PM »
I have sent you a personal message.
4ideas
Active Member
Offline
Reply #4 on:
July 26, 2011, 11:50:35 PM »
Good morning Hood
Attached please find the updated XML file as discussed last night.
4ideas
3D cutting.xml
(100.58 KB - downloaded 18 times.)
Active Member
Offline
Re: Re: Jogging & feedrate troubles (Mach 3 Mill)
Reply #5 on:
July 27, 2011, 03:26:35 AM »
Have yo tried since you put the licence in the folder?
Will go look at the xml anyway in case I see some issues.
Active Member
Offline
Reply #6 on:
July 27, 2011, 03:33:58 AM »
Your xml is set to Exact Stop as default and your code has not got a G64 in it so it will run in Exact Stop. Best to put a G64 at the beginning of the code and probably also best to change the default to G6 (Constant Velocity), yo can do that on General Config page.
4ideas
Active Member
Offline
Reply #7 on:
July 27, 2011, 01:58:50 PM »
Thank you much sir! Will give it a try....
4ideas
Active Member
Offline
Reply #8 on:
July 27, 2011, 02:05:45 PM »
Just noticed I had a typo above, I said
Quote from: Hood on July 27, 2011, 03:33:58 AM
It should be G64 (Constant Velocity)
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
