Hello Guest it is June 10, 2026, 12:48:41 PM
Author Topic: Scan 3D in mach3  (Read 34255 times)
Scan 3D in mach3
« on: July 19, 2011, 08:03:31 AM »
Hello.
anyone know how to do this with Mach3.
http://www.youtube.com/watch?v=17hMjPB44PM
tracking scan an object from the axis X or Y.
Nacho
Offline GaryB
  •  108 108
Re: Scan 3D in mach3
« Reply #1 on: July 19, 2011, 08:57:51 AM »
hook up your probe and run the digitize wizard
« Last Edit: July 19, 2011, 08:59:33 AM by GaryB »
Beckwith Decor Products
ArtCam Trainer
Onsrud & Custom CNC tooling Distributor
Wichita/Derby Kansas
http://www.beckwithdecor.com
« Reply #2 on: July 19, 2011, 09:58:34 AM »
the answer is not valid.
 watch the video, wait 2 minutes of playback.
 really that scans from the axis X.
 moving along the X axis and Z axis ascending when it touches the workpiece.
 is not what makes the Mach3,
Nacho
  •  9,356 9,356
« Reply #3 on: July 19, 2011, 11:30:36 AM »
The Impact / Laser plugin that I use for laser engraving was developed from a Mach probing routine. The source code for this plugin is available from the plugin’s page and if you take a look at the code you will see that it is already two thirds of the way towards the probing routine shown in the video clip.
OK you would need to know a little C++ but it would not be rocket science for you to adapt this plugin to suit your own needs if you are determined enough.
Just a thought.
Offline GaryB
  •  108 108
« Reply #4 on: July 19, 2011, 03:15:06 PM »
I actually went and watched the video and see what you meant.
I assume it only runs on their controller as a plug in software
ArtCam Trainer
« Reply #5 on: July 19, 2011, 05:14:01 PM »
Yep that is a NICE 3d probing routine.
« Reply #6 on: July 20, 2011, 01:28:15 AM »
Hello.
 I agree with you.
  but I want to know is:
 Mach3 can do?
 Has anyone done it?
 It is a good beginning to develop a plugin or routine scan, I do not know much about software.
this is my machine.
http://www.youtube.com/watch?v=gYh70ZxjiS8
 I have changed the stepper motors for AC servo motors with encoders.
 fast scanning system is the only thing I'm missing.
Nacho
« Reply #7 on: July 20, 2011, 12:17:46 PM »
Is this probing routine run inside Deskcnc?
« Reply #8 on: July 20, 2011, 12:29:57 PM »
no.
 works with an electronic circuit and a software called "colibri CNC" of the Italian company Twintec.
Nacho
« Reply #9 on: July 20, 2011, 12:58:47 PM »
I would say that Stirlings Crawler method for probing would stand a chance or could be modified to do the job.
