Hello Guest it is October 09, 2026, 02:23:09 AM
Author Topic: Scan 3D in mach3  (Read 39656 times)
Re: Scan 3D in mach3
« Reply #10 on: July 20, 2011, 01:05:07 PM »
Happen to know the price of software and circuit?
Does the circuit control the drives and everything? Or piggybacked with Mach?
« Reply #11 on: July 20, 2011, 01:28:38 PM »
the main board it, 276 euros.
 the software is free and only works with the plate connected to USB.
web.
http://shop.twintec.it/
Nacho
« Reply #12 on: July 20, 2011, 01:47:40 PM »
Sounds good!
But, does main board control drives? Or does it work with Mach?
« Reply #13 on: July 20, 2011, 01:57:59 PM »
Hello.
 can not be controlled by Mach3.
 electrical circuit with the software generates pulses to control 6 axes. direction and speed, multiple inputs and outputs.
 I may buy the track, but I mounted the control panel to Mach3 and now will not work half the things the control panel.
 Mach3 is unfortunate that not scan this way,
 Nacho
« Reply #14 on: July 20, 2011, 03:05:58 PM »
Mach is capable of doing what you see "BUT" no one has programmed a plugin to do a scan like this. Art started a version to do it BUT retired before it was debugged.
« Reply #15 on: July 21, 2011, 01:20:06 AM »
good.
 I'm glad that response.
 known if masters "Art" investigate, solve our problems,
 ;D "MACH3 live long." ;D
 as we push, the leading researchers in this field.
would be a good time to start a system scan but good for Mach3
 Thank you.
Nacho
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #16 on: July 21, 2011, 02:16:53 AM »
I would say that Stirlings Crawler method for probing would stand a chance or could be modified to do the job.
For 275 euros a shot I'd modify it to make the tea as well. Actually on second thoughts - make that GBPounds - euros arn't looking such a good bet...
Ian
« Last Edit: July 21, 2011, 04:19:12 AM by stirling »
