Hello Guest it is June 12, 2026, 08:35:58 AM
Author Topic: 24 volt proximity switches  (Read 8336 times)
« on: July 08, 2011, 02:10:15 AM »
Hi Everyone I need some help
I am converting a Chinese router from DSP controller to Mach 3 , I have a BOB and speed control board from Peter Homann as well as the 5volt power supply for these, originally the machine was fitted with SN04-N 24 volt proximity switches which have their own power supply. I want to keep these and was advised to use an Opto22 G4PB4 board and G4IDC modules as an interface between the 24 volt side and the 5volt Breakout Board.
I am not the worlds most brilliant at electronics and cant seem to get the wiring set up that I get a 24v signal in one side and 5v out the other? Can someone give me some easy to follow directions please?
Will
  •  9,356 9,356
Re: 24 volt proximity switches
« Reply #1 on: July 14, 2011, 06:16:48 AM »
Hi Will,
If you take a look at this document (Section 7) it gives details of proximity switch connections for 12 & 24 Volt / NPN and PNP versions. http://cnc4pc.com/Tech_Docs/C10R10_USER_MANUAL_V2.pdf
Hope this helps,
« Reply #2 on: July 15, 2011, 02:55:52 AM »
Thanks for that Tweakie, I think I have sorted it out now, on with the rest of the job!
Will
  •  9,356 9,356
« Reply #3 on: July 15, 2011, 03:30:19 AM »
Hi Will,
I am glad you have it sorted.
Don't forget to post some pictures of things you make once it is all 'singing and dancing'.  ;)
