May 28, 2012, 01:36:55 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  New Joystick
Pages: 1   Go Down
Print
Author Topic: New Joystick  (Read 291 times)
LAMEIII
Active Member
Offline Offline
View Profile
« on: July 07, 2011, 04:23:58 PM »
I'm a newbie to CNC but have been having a lot of fun learning the software and Mach3. I just purchased a Logitech Attack 3 Joystick with 11 buttons. I have it installed on my computer and it appears to be working correctly. At this point the only thing I want to use it for is controlling the X, Y, & Z axis.
What I need to do now is get it into Mach 3 (V 3.043.022). I've read numerous threads on Joysticks but that has only confused me. I see references to several different plugin's and don't know which to use or how to set it up..
Any help would be greatly appreciated
Lame
rolexmechanic
Active Member
Offline Offline
View Profile
« Reply #1 on: July 10, 2011, 09:37:39 PM »
Have you run keygrabber yet? It is in the mach folder that was installed with the program.
LAMEIII
Active Member
Offline Offline
View Profile
« Reply #2 on: July 11, 2011, 07:51:05 AM »
I've read through the installation manual for Joypad 2.0 and it makes no mention of running keygrabber.
Is it necessary?Huh
Lame
rolexmechanic
Active Member
Offline Offline
View Profile
« Reply #3 on: July 11, 2011, 10:06:04 AM »
First, under the config heading (top left) drop down menu there is one called conffig plugins. When that comes up check and configure joystick.
keygrabber is a little program that allows use orf the buttons on the joystick. just found that myself no t long ago.
Hope that works for you.
Dwight
« Last Edit: July 11, 2011, 10:08:26 AM by rolexmechanic@comcast.net » Logged
Pages: 1   Go Up
Print
Jump to:
