Thanks for laying it all out so clearly Rich. I have cross checked my results (using the standard Mach3 Turn xml AND my customized one, SBLathe) on the testbed PC and everything matches up to your outputs in both Radius and Diameter mode which makes me happy
I have to check all of this on the lathe itself, but using the same xml should give me the same results. The strange thing is still that what was actually cut using the SBLathe xml doesn't look like either of your drawings. The nose is very blunt, almost like it cut 27 degrees as measured from the face and not the axis. It's similar to your first drawing if it were rotated 90 degrees CCW.
It definitely looks like I need to stay in Diameter mode to use this wizard. I'll experiment more and try to find what I may be doing to mess this up, and post it here of course. Thanks again!
Mr. Technical
