Hello Guest it is June 11, 2026, 04:29:54 PM
Author Topic: removing programs from pc to help mach run? GER21 comment  (Read 8052 times)
« on: June 21, 2011, 02:09:16 PM »
"Be prepared to remove your anti virus software, quicktime, video editing software, and many others if you want to use your main PC to run Mach3."ger21 quote
I have issues with mach3 locking up my computer. Ground to this or that, doesn't matter. I need to delete these other programs? Can I get a full list?
i_r_machinist
Re: removing programs from pc to help mach run? GER21 comment
« Reply #1 on: June 21, 2011, 02:46:48 PM »
Acrobat and Quicktime are the two that are known to often cause problems. AV has never been an issue for me but I have only used AVG so other ones could cause issues.
« Reply #2 on: June 22, 2011, 07:26:01 AM »
I removed adobe and quicktime last night. Also turned off all windows security. I'll run this Friday and see how it goes.
i_r_
  •  9,356 9,356
« Reply #3 on: June 22, 2011, 07:36:52 AM »
i_r_,
Just an observation, but it is always best to have a dedicated PC, with minimum install, just for Mach and then keep your main PC for the CAD/CAM work etc.
(My machine PC is nothing special, runs XP sp2, and was obtained 'second user' for silly money).
