Hello Guest it is June 09, 2026, 09:35:47 PM
Author Topic: Mach Crashed - won't restart after setting kernel speed too hi  (Read 8819 times)
I guess I need to know how to change the kernel speed outside of Mach.  I don't find anything called Kernel in Mach3Mill.xml, so evidently the kernel speed setting is called something else or held in another location...
What's the trick?
Thx
Scott Kelley
Re: Mach Crashed - won't restart after setting kernel speed too hi
« Reply #1 on: June 13, 2011, 05:22:24 AM »
<PulseSpeed>
0
</PulseSpeed>
Is what you want to change, 0 is for 25KHz, 1 is 35KHz, 2 is 45KHZ etc.
« Reply #2 on: June 13, 2011, 05:14:18 PM »
Thank you!
Scott
« Reply #3 on: June 13, 2011, 05:16:15 PM »
No probs :)
« Reply #4 on: June 13, 2011, 09:23:24 PM »
IF mach crashes you may need to rerun the driver test so that it can restart.
Just a thought, (;-) TP
