Mach Discussion => General Mach Discussion => Topic started by: Scott Kelley on June 13, 2011, 05:50:02 AM
I guess I need to know how to change the kernel speed outside of Mach. I don't find anything called Kernel in Mach3Mill.xml, so evidently the kernel speed setting is called something else or held in another location...
What's the trick?
Thx
Scott Kelley
<PulseSpeed>
0
</PulseSpeed>
Is what you want to change, 0 is for 25KHz, 1 is 35KHz, 2 is 45KHZ etc.
Thank you!
Scott
No probs :)
IF mach crashes you may need to rerun the driver test so that it can restart.
Just a thought, (;-) TP
