Hello Guest it is June 11, 2026, 04:13:29 PM
Author Topic: Latest update problem  (Read 6911 times)
« on: June 06, 2011, 08:56:06 AM »
I have just down loaded and installed  R3.043.022 on win 7 32 bit. I use TurboCAD15 Cad/Cam.
I only use this system to create the original files but use XP on the actual machine output.
The arc locations now seem to be in the wrong place,the linear postions are Ok.
See attached file.The first file I used was more complicated so drew anothersimple  one to prove the point with the same result.
Does anyone have any suggestions please.
Regards
Roger
The second picture is what I expected it to be.
« Last Edit: June 06, 2011, 08:59:56 AM by Rogeman »
Re: Latest update problem
« Reply #1 on: June 06, 2011, 02:34:51 PM »
Dredging my memory I had a similar problem a while ago.
I cured it by changing my cam settings to output arcs in max 90 degree section.
ATB
Derek
You can "chop it off" but can't "chop it on"
« Reply #2 on: June 06, 2011, 04:04:39 PM »
Hi Derek,
Thanks for you reply, I am not sure how to achieve that with Turbocad/cam.
As I said it only occured when I updated to the latest Mach3, it was Ok with Ver. 2.6
I have run the same file on 2.6 no problems.
Regards
Roger
