Hello Guest it is June 10, 2026, 04:58:38 PM
Author Topic: Tool plate/setter wiring.  (Read 30954 times)
  •  9,356 9,356
Re: Tool plate/setter wiring.
« Reply #20 on: May 28, 2011, 12:38:30 AM »
Hope this makes sense.
« Reply #21 on: May 28, 2011, 12:41:12 AM »
Yes it does,
  Cutting and re-solding as we speak.
« Reply #22 on: May 28, 2011, 01:28:59 AM »
Al right,
The LED comes on when the clip and plate are touched (I believe it was supposed to be on then go off) . I tried using the code of yours yet it doesn't set the DRO. I believe in the script phase now. WOO HOO.
The schematic was great help.
« Reply #23 on: May 28, 2011, 01:53:02 AM »
CORRECTION
The script is working. I wasn't watching the DRO close enough
  •  9,356 9,356
« Reply #24 on: May 28, 2011, 03:25:01 AM »
Great news Craig. Pleased you have it working. (the LED is usually off and only comes on when the plate is touched)
« Reply #25 on: May 28, 2011, 01:55:10 PM »
Can you direct to scripts for programing the X/Y  + & - buttons. I'll do some searching in the mean time
Thanks again.
