May 27, 2012, 08:55:29 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Simple, Simple question about home.
Pages: 1   Go Down
Print
Author Topic: Simple, Simple question about home.  (Read 223 times)
RChadwick
Active Member
Offline Offline
View Profile
« on: April 27, 2011, 03:39:46 PM »
I lost the config to my machine, and I'm recreating it. This is my last challenge:
How can I tell Mach3 to start somewhere other than 0,0? I have limit switches that set home, but I have a fixture mounted an inch or so away, and want it to always start from there. I'm sure I'm missing something obvious, but the more I play with it, the more frustrated I get, and I'm not getting any closer.
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #1 on: April 27, 2011, 04:04:47 PM »
You could set a home off distance in homing and limits or use a fixture offset which would be best I think.
Grin If you could see the things I have in my head, you would be laughing too. Grin
www.precisionchaos1.com
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #2 on: April 27, 2011, 04:31:15 PM »
If you want to always start from a certain spot, you'll probably want all your g-code to finish in that spot.
Unless you  are only talking about when you firs home the machine, than use Home Offsets like Brett said.
Pages: 1   Go Up
Print
Jump to:
