Hello Guest it is June 12, 2026, 09:13:28 PM
Author Topic: Safe z moves question  (Read 9920 times)
« on: April 10, 2011, 09:51:29 PM »
I recently purchased the Newfangled wizzards and am having troubles with z moves .
When I post code and get sent to the run program, I press cycle start Z moves off of part to top of z and status replies with a "Safe Z moved Down to  Soft Limit Minimum" , I played with offsets g54 and g55 and still same response, What am I doing wrong??
Re: Safe z moves question
« Reply #1 on: April 11, 2011, 02:53:54 AM »
Can you attach your xml please as it will be the easiest way to see how you have things set up. It does sound like your safe Z and Soft limits are conflicting.
Also post the code if possible.
« Reply #2 on: April 11, 2011, 12:15:53 PM »
Here the xml and gcode file thanks.
« Reply #3 on: April 11, 2011, 12:34:51 PM »
You have a safe Z set as 101.6 in machine coords, the most you can go is 0 in machine coords so set it to zero or maybe -0.01 or something.
« Reply #4 on: April 11, 2011, 02:10:42 PM »
Defiinitly over looked that Thanks Hood your the man
What a difference
« Reply #5 on: April 11, 2011, 03:07:01 PM »
Glad it sorted the problem :)
