Mach Discussion => General Mach Discussion => Topic started by: vatorman on April 10, 2011, 10:51:29 PM
I recently purchased the Newfangled wizzards and am having troubles with z moves .
When I post code and get sent to the run program, I press cycle start Z moves off of part to top of z and status replies with a "Safe Z moved Down to Soft Limit Minimum" , I played with offsets g54 and g55 and still same response, What am I doing wrong??
Can you attach your xml please as it will be the easiest way to see how you have things set up. It does sound like your safe Z and Soft limits are conflicting.
Also post the code if possible.
Here the xml and gcode file thanks.
You have a safe Z set as 101.6 in machine coords, the most you can go is 0 in machine coords so set it to zero or maybe -0.01 or something.
Defiinitly over looked that Thanks Hood your the man
What a difference
Glad it sorted the problem :)
