May 27, 2012, 07:00:28 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Fixture Save?
Pages: 1   Go Down
Print
Author Topic: Fixture Save?  (Read 235 times)
kolias
Active Member
Offline Offline
View Profile
« on: March 27, 2011, 11:26:01 AM »
When I close Mach3, why some times I get the message "FIXTURE SAVE?"
Should I say Yes / No, what is the difference?
Nicolas
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #1 on: March 27, 2011, 11:34:13 AM »
In general Config, bottom right, "Optional Offset Save" controls that.
Whether or not you want to save the current offsets is up to you. If you zero all your axis each time you run a part, than you don't really need to save them. But if you want to keep your offsets from session to session, then you should save them.
You can save them any time you want from the offsets page, btw.
kolias
Active Member
Offline Offline
View Profile
« Reply #2 on: March 27, 2011, 01:16:00 PM »
Got it, thanks Gerry
So it refers to Offset Save and for my needs I removed the tick from the general config. Normally I put a piece on the table and bring the axes where I want each time because I never use the same position.
Perhaps this option is good for people who do repetitive work at the same spot
Nicolas
Pages: 1   Go Up
Print
Jump to:
