Hello Guest it is June 10, 2026, 08:36:00 PM
Author Topic: Config/Motor Turning  (Read 20398 times)
« on: March 27, 2011, 12:46:19 AM »
This portion seems incomplete.
Can you throw in Steps Per Revolution, lead screw TPI, Inches per minute,  Additional acceleration rate.
I can't find accuracy with the way its set up right now. You just have it listed as Steps Per. Steps per what? meter, yard or mile?
Re: Config/Motor Turning
« Reply #1 on: March 27, 2011, 12:52:55 AM »
Ah yes. don't forget to add Microstep to it too.
so it would be like:
StepsPerRev: 200, leadscrew TPI: 32, MicroStep:16, TravelRate:0.30" per minute, acceleration rate:1 to 100%
this way accuracy would be higher.
Also, allow people to enter in their own Kernel rates in the config ports and pins. The kernel rates posted are not compatible mathematically with my hardware.
« Reply #2 on: March 27, 2011, 06:10:48 AM »
Link to a steps per unit calculator:
http://www.machsupport.com/forum/index.php/topic,16315.msg110286.html#msg110286
Steps/unit.........thus  inches or mm
Don't understand your comment.  ???
The kernel rates have to do with Mach's interface with Windows operation.
« Reply #3 on: March 27, 2011, 10:40:30 PM »
could you provide the xls in jpg, txt, doc or bmp format? I can't view xls.
« Reply #4 on: March 28, 2011, 04:39:24 AM »
I can't view xls
You will need Ms Excel to use the calculator.
« Last Edit: March 28, 2011, 04:41:05 AM by RICH »
