Hello Guest it is June 10, 2026, 07:06:09 AM
Author Topic: PC won't boot up  (Read 17272 times)
PC won't boot up
« on: March 24, 2011, 02:13:41 PM »
Need help.
This was intermittent for several start ups, now won't work at all.
PC starts to boot up, then a message .. "CPU FAN is not connected".
The fan is plugged in to the mobo but looked like it was spinning at about half speed.
I put another fan on and it spins up to what looks like a normal speed but the PC still won't boot up.
Get the same message then it shuts down.
Yesterday after 4 attempts, it finally took off and ran normally.
Now it won't start even after umpteen attempts.
Any help needed badly.
Russ
Re: PC won't boot up
« Reply #1 on: March 24, 2011, 02:25:49 PM »
You could start on the bios and disable the CPU fan warning.
This not really recommended but give it a try.
Jeff
« Reply #2 on: March 24, 2011, 02:32:35 PM »
Hi Jeff,
How do I get there.
There is a very brief screen, then the message.
« Reply #3 on: March 24, 2011, 02:42:28 PM »
Depend on what type of computer you have.
It is written when the computer boot.
Normally, this key is Delete
Jeff
« Reply #4 on: March 24, 2011, 02:45:25 PM »
Normally, is you can enter in the BIOS, you should find under PC Health status the RPM for the fan.
If is is spinning, try reducing the RPM a bit to see if it's make any difference.
Jeff
« Reply #5 on: March 24, 2011, 03:08:09 PM »
Jeff,
This is the only screen I get for about 3 seconds, then the FAN message, then it cuts OFF.
I can't get to the bios or anything else.
It is just a mobo mounted in my panel, not sure what it is. lol
« Reply #6 on: March 24, 2011, 03:23:18 PM »
when booting up, if you keep hitting DEL key, you can't get access to the BIOS???
This sound bad, look like a bad hard dive.
But even with a bad HDD, you should be able to access BIOS
Jeff
« Reply #7 on: March 24, 2011, 03:28:54 PM »
Try downloading the manual for your mobo.
Sometime on some mobo, there's a jumper to skip or prevent access to the bios.
What brand and model is it.
Jeff
« Reply #8 on: March 24, 2011, 03:37:04 PM »
If your computer does not boot at all, you will probably need to clear bios setup, it may be corrupted.
Or just to be sure, verify that keyboard is connected.
Jeff
« Reply #9 on: March 24, 2011, 03:58:08 PM »
To be honest Russ it sounds like the mobos sensor is screwed but check the fan is connected properly and to the right header as often there are at least 2 or 3 fan headers. Also worth cheking the wires on the fan as there should be at least 3 possibly 4, if the fan you put on is from an old computer it may just have 2 wires.
