Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 06:11:14 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Is is possible that some motherboard does not work with Mach3
Pages:
1
2
3
4
Go Down
« previous
next »
Author
Topic: Is is possible that some motherboard does not work with Mach3 (Read 1457 times)
Active Member
Offline
Carnoustie, Scotland
Re: Is is possible that some motherboard does not work with Mach3
Reply #30 on:
March 23, 2011, 06:22:39 PM »
Jeff I was meaning the Mach driver, see if uninstalling it from device manager makes a difference.
ostie01
Active Member
Online
Reply #31 on:
March 23, 2011, 10:19:32 PM »
I know you would say that.
Just saw your post and I was in the shop and I did un-install the driver or disabled it and it did not make any difference.
The only thing I could think of is all motherboard are from ECS , all K7 model with different CPU and Graphic card and memory stick and HDD.
I did put another HDD I had with the mobo I received today, format and install Mach3 without any other driver.
CPU get as high as 30 to 40% when running the mouse over the Mach3 windows, tried installing Mach3 V3.042.040 and nothing changed, returned to Mach4 v 3.043.022
Still trying on the system that is hooked up to the router.
When moving the mouse on the desktop, CPU is at 2 to 3%, when moving mouse over mach3 windows, get to 60% CPU usage.
When running to router without the spindle, keep mouse and keyboard, if I turn on the spindle, instantly loose the mouse.
I tried to disable LPT1, PCI parallel port, video driver, USB driver, Sound driver, LAN driver, Modem driver and no change, Enable them all again.
Will remove the VFD from the control box and place it on the back of the Z axis, I have place for that and will hook up low power cable from control box to the VFD instead of High
power cable from control box to the Motor, another test on the go.
Jeff
Tweakie.CNC
Active Member
Offline
Super Kitty.
Reply #32 on:
March 24, 2011, 02:04:05 AM »
Perhaps now would be a good time to replace the computers ATX power supply and check all the connections.
Success consists of going from failure to failure without loss of enthusiasm. Winston Churchill.
ostie01
Active Member
Online
Reply #33 on:
March 24, 2011, 03:44:47 AM »
I did place another VFD I had on hand on the back of the Z axis rather than in the control panel
Now they're no more interference to the computer.
Been able to do a couple of jobs without loosing the mouse and RPM is steady.
Still get a high CPU usage but if I do not play with the mouse during machining, I will accept that and make some more testing later.
Will remove the other VFD from the control box and verify inside if they're something wrong.
About power supply, I have 3 computer board running right now, each with it's own HHD, power supply, video card, memory and they all have high CPU usage when running mach3.
What version do you use right now, mine is 3.043.022
Jeff
Tweakie.CNC
Active Member
Offline
Super Kitty.
Reply #34 on:
March 24, 2011, 11:18:32 AM »
Looks like you have solved the problem then.
Pages:
1
2
3
4
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
