May 27, 2012, 05:08:46 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Tool change
Pages: 1   Go Down
Print
Author Topic: Tool change  (Read 327 times)
rickw
Active Member
Offline Offline
View Profile
« on: March 03, 2011, 01:05:18 PM »
I have a question relating to changing tools (cutting bits). So far, I have been using the same cutter for all of my jobs so there was no need to worry about a tool change. Now I want to add some different textures to projects and I do not have a tool changer. How does one ensure Mach is aware to pause and change locations for a manual tool change and then move back to the next cut?
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: March 03, 2011, 01:16:40 PM »
General Config has options for tool change.
rickw
Active Member
Offline Offline
View Profile
« Reply #2 on: March 03, 2011, 03:39:53 PM »
I changed the option in Gen Config to manual, now how will this effect my change? Will I move the spindle to a different location and change the tool, then zero the the cutter on the surface of the material? If so, what is my next step? How will the cutter get back to where I left off?
Active Member
Offline Offline
View Profile
« Reply #3 on: March 03, 2011, 04:09:56 PM »
You should be able to simply move away, change tool, move down and touch off/zero then move up again and press Start, might be best to move back to almost where the next code should start. Always be ready withthe E-Stop until youget used to things though as often your code may have something in it that you are not expecting, especially when new to things.
rickw
Active Member
Offline Offline
View Profile
« Reply #4 on: March 03, 2011, 04:41:42 PM »
Sweet, thanks Hood!
Pages: 1   Go Up
Print
Jump to:
