May 27, 2012, 04:35:31 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Aluminum Bearing Block
Pages: 1   Go Down
Print
Author Topic: Aluminum Bearing Block  (Read 467 times)
kolias
Active Member
Offline Offline
View Profile
« on: February 23, 2011, 07:56:44 AM »
The attached picture represents a bearing block made out from an aluminum flat bar 1” thick by 2”x 3” with four 1/4" mounting holes and one hole 1-1/16” in the center for the bearing.
My question here is that I see these red lines (are they called Rapids ?) appearing to be much higher than the aluminum piece.
Am I doing something wrong or it supposed to be like that?
Nicolas
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #1 on: February 23, 2011, 08:31:27 AM »
Nicolas,
They will be related to your 'safe Z' setting either within Mach or the software you used to create the part.
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #2 on: February 23, 2011, 09:31:11 AM »
Correct me if I'm wrong (don't have Mach3 installed here), but the SafeZ setting in Mach3 has nothing to do with the rapid height.
Rapid height is controlled by your CAM software.
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #3 on: February 23, 2011, 10:44:34 AM »
Gerry is right  Cry
kolias
Active Member
Offline Offline
View Profile
« Reply #4 on: February 23, 2011, 11:45:34 AM »
So the rapids height is wrong as indicated?
Nicolas
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #5 on: February 23, 2011, 11:53:49 AM »
No, not wrong, just more travel than you perhaps really need.
Global Moderator
Offline Offline
View Profile
« Reply #6 on: February 23, 2011, 05:48:31 PM »
I don't know what program you are using, but for LC, see see Tutorial #6 in the manual.
kolias
Active Member
Offline Offline
View Profile
« Reply #7 on: February 23, 2011, 08:18:30 PM »
Thanks RICH I was already there and now I can see that these red lines are the Rapid Heights. Since this subjects involves LC and I have more questions, I will start another post in the LC section of the forum.
I want to start some cutting with LC to familiarize myself with the techniques and then I plan to purchase a more dedicated CAM software
Nicolas
Pages: 1   Go Up
Print
Jump to:
