Hello Guest it is June 10, 2026, 09:53:31 PM
Author Topic: What Happened To My Code?  (Read 9116 times)
« on: February 21, 2011, 11:04:27 PM »
Greetings,
I've been using the same Mach 3 version (Only 6 months old) and my computer is dedicated to my CNC Mill (no internet nothing),  The past couple days my posts (not all of them but usually half) have been corrupted or something.  I do all my drawings on Coral Draw X4, then I use the Leonard Software to export the DXF, then into Visual Mill then I post it to Mach 3.  This is crazy and driving me almost the same tiring to figure this out.  Any idea or suggestions would be great.  I have added a picture to this post.  Look at the purple circles on the display.  WHY?
Dennis
Re: What Happened To My Code?
« Reply #1 on: February 21, 2011, 11:10:02 PM »
Could be some lead in lead out problem (probably not) or look in General config and verify if I.J. is incremental or absolute. Must be incremental
Other than that, don't know
Jeff
« Reply #2 on: February 21, 2011, 11:11:40 PM »
You could also post your code, this will help others to see what could be the problem
Jeff
« Reply #3 on: February 21, 2011, 11:17:01 PM »
I will see if I can find the code.  It maybe at work.  In Visual Mill I run the simulation and the purple swirls are not there.  It only occurs when I open the post in Mach3, if that helps.
I thought I would add this information.
Dennis
« Reply #4 on: February 21, 2011, 11:27:48 PM »
You code is probably good but Mach3 will take into account how it is set.
« Reply #5 on: February 22, 2011, 03:28:52 AM »
Change the IJ mode on General Config to the opposite of what it is now.
Ideally your code should contain either G90.1 or G91.1 depending on which mode your CAM is posting arc code, that way it will not matter what is set as default in Mach.
