Hello Guest it is June 11, 2026, 04:16:40 PM
Author Topic: Grease pump  (Read 38389 times)
Re: Grease pump
« Reply #30 on: March 03, 2011, 01:14:29 PM »
Possibly because the On/Off/On state is faster than 10Hz? In other words, at 20m/min your axis is moving 333.333mm/second so 1/10 of a second it moves 33.333mm so if your screw hole is less than 33mm dia (very likely) then there is a good chance the brain will miss it.
« Last Edit: March 03, 2011, 01:21:11 PM by Hood »
Re: Grease pump
« Reply #31 on: March 03, 2011, 01:37:47 PM »
So the switch must be ON for more than 0.1s and OFF for more than 0.1s to make the count?
Re: Grease pump
« Reply #32 on: March 03, 2011, 01:47:49 PM »
The brain has to see it, if the brain works at Machs update (10Hz)  then your on/off/on state is likely much shorter than 1/10th of a second so there is a good chance the brain will not see it.
