Hello Guest it is June 13, 2026, 08:35:16 AM
Author Topic: Hold Down Clamps  (Read 27931 times)
Offline kolias
  •  1,165 1,165
Hold Down Clamps
« on: February 16, 2011, 07:17:53 AM »
Any ideas about hold down clamps for a CNC Router machine?
Nicolas
Re: Hold Down Clamps
« Reply #1 on: February 16, 2011, 11:00:40 AM »
what kind of table do you have?
Offline kolias
  •  1,165 1,165
« Reply #2 on: February 16, 2011, 11:29:56 AM »
Here is a photo of the table top. For now I have these 2 pieces which will hold a piece in place but wondering if there is any better idea.
The slots on the table will take any std. T-Slot bolt, and the table top is 3/4" plywood
Nicolas
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #3 on: February 16, 2011, 12:24:02 PM »
I really like the A2Z toggle clamps. They have a wide clamping range and are available in several sizes so you can get the size that fits your machine and clamping jobs. Take a look at: http://www.soigeneris.com/A2Z_Milling_Clamps-details.aspx (my website). I use them all the time and love them.
Happy machining , Jeff Birt
Offline kolias
  •  1,165 1,165
« Reply #4 on: February 16, 2011, 12:50:39 PM »
That's a good alternative Jeff but kind of expensive since its a very good quality
Another alternative I had in mind is like the attached picture but they are out of stock until April. I used them on my 1st CNC and they worked very good
http://www.busybeetools.com/products/HOLD-DOWN-FOR-B238424%7B47%7D36.html
Perhaps other members may come up with more ideas
Nicolas
« Reply #5 on: February 16, 2011, 06:59:41 PM »
Offline kolias
  •  1,165 1,165
« Reply #6 on: February 16, 2011, 07:37:36 PM »
Very good idea Gerry, I like that
Nicolas
« Reply #7 on: February 16, 2011, 09:34:22 PM »
You can get that style of clamp for a few $ each from almost anywhere that sells woodworking supplies.  Rockler.com is one good source.
Offline kolias
  •  1,165 1,165
« Reply #8 on: February 16, 2011, 10:17:18 PM »
Didn't know that Rockler has them, now I saw them and a good price for 2
Nicolas
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #9 on: February 17, 2011, 06:17:49 AM »
I'm not a big fan of having big knobs that always seem to be in the way. You can make some really inexpensive clamps from aluminum angle with a hole drilled through on side. They are inexpensive but not very flexible. I use them at times where there is a chance that the tool may hit the clamp and there are no other good options. Since they are aluminum and cheap you can cut right through them with no worries.
