Hello Guest it is October 12, 2026, 06:48:37 PM
Author Topic: Hold Down Clamps  (Read 32771 times)
Re: Hold Down Clamps
« Reply #10 on: February 18, 2011, 08:00:56 PM »
So my table is setup and running now.
Wandering if any of you made your T slot tables?
After building table, software, and accessories I didn't have the $ to buy T slot's so I was going to use shelf pegs. Insert where needed in pre drilled holes.  Said holes are 1" apart with odd rows offset 1".
BUT I like the idea of being able to hold the piece down and not just from sliding around.
If so How did you make your T slot tables?
Offline kolias
  •  1,165 1,165
« Reply #11 on: February 18, 2011, 08:27:30 PM »
Here are some photos of my T-Slots
On the bottom I used 1/4" thick MDF and at the top I used 3/4" plywood
The bolt is standard 1/4-20 carriage bolt
Nicolas
« Reply #12 on: February 18, 2011, 09:30:11 PM »
Why dont you make you own clamps I was looking at buying some didnt have the money Then in the v carve pro forum someone put a posting on making clamps   All it was was a 3/4 inch board the clamp is 2 inches wide about 4 inches long  make one step 1/3 the thickness then another step with a 1/4 inch left. This will leave 3 steps one 3/4 inch thick one1/2 inch thick one 1/4 inch thick. I set up the cutter to cut 5 wide on the board  put a few rows and in 20 minutes I had 30 clamps made at a few cents each. Oh I had to put a hole in them to put a screw threw to clamp them to the table top. bolt head soldered or brazed to a washer with both sides flattend will make a T bolt.Put a wing nut on the top  Simple and looks like they were bought.
Offline kolias
  •  1,165 1,165
« Reply #13 on: February 18, 2011, 10:09:38 PM »
A good tip Larry, thanks
Nicolas
« Reply #14 on: February 19, 2011, 02:58:13 PM »
Thanks kolias - wish I done that from the get go.
I will put it on my 2 Do list.
Along with the DIY clamps.
