Hello
Guest
it is
June 11, 2026, 06:51:57 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Importing G code
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Importing G code (Read 18710 times)
Overloaded
4,923
Re: Importing G code
Reply #10 on:
February 06, 2011, 07:50:20 PM »
I'd say you have to do as you said in your first post.
The ORIGIN needs to be closer to, or on the profile.
If you draw a 1" dia. circle and have the 0,0 origin 5' away, you'll get what you are seeing.
From my limited experience,
Russ
Overloaded
4,923
Reply #11 on:
February 06, 2011, 07:52:38 PM »
Just be sure to define the 0,0 origin every time you use the CAM.....never have to go back then.
rickw
110
Reply #12 on:
February 06, 2011, 08:40:46 PM »
Okay, I get it now. I am trying to figure out the zeroing part. Can one zero on a certain point on the material you are cutting? I have a piece of stock not much bigger that what I want to cut. Can I zero in a certain mark on the stock to ensure the positioning? Can I zero on this mark and expect it to be 0,0 on the work offset?
Last Edit: February 06, 2011, 08:46:40 PM by rickw
Overloaded
4,923
Reply #13 on:
February 06, 2011, 09:28:01 PM »
Yes, exactly right on all accounts.
It can be anywhere you wish. On the part or on the fixture or anywhere you like.
Just be sure to define it.
ger21
6,295
Reply #14 on:
February 06, 2011, 09:34:17 PM »
Ideally, you should be drawing your parts in AutoCAD in the positions you want to cut them, relative to the origin.
rickw
110
Reply #15 on:
February 07, 2011, 08:35:33 AM »
Thanks Jerry, now I know I need to be aware of this when drafting and editing.
Print
Pages:
1
2
Go Up
« previous
next »
