Hello Guest it is June 12, 2026, 03:24:06 PM
Author Topic: Need Help with "Rquested Home Axis Home Swithch"  (Read 25568 times)
Re: Need Help with "Rquested Home Axis Home Swithch"
« Reply #10 on: February 01, 2011, 04:15:26 PM »
Dont think so but easy enough to try, just rename it to something else and start the reanmed profile and you will still be able to go back to your previous xml if needed.
If you have tested that there is continuity through the two wires that connect to your BOB from the switches then it would seem the BOB is not passing the signal.
« Reply #11 on: February 02, 2011, 12:40:48 PM »
Hood U R THE MAN! The input on the BOB quit. bummer I really need all 4 inputs I wish I knew what killed it?
Figula
« Reply #12 on: February 02, 2011, 01:40:00 PM »
What kind of BOB do you have?
« Reply #13 on: February 02, 2011, 04:38:02 PM »
Gecko G540
Figula
« Reply #14 on: February 02, 2011, 04:48:27 PM »
Have you contacted Gecko? they are usually very good with repairs.
« Reply #15 on: February 02, 2011, 07:49:29 PM »
Yes! By ;) email, they were back PDQ. FYI the GECKO tech want it back to check to determine if it's the Term. Block or the input relay. "I'll put money on the Guts. Anyway my studio is backed up and I can't do the PA. to CA. to PA. downtime. The GroundHog didn't see his shadow this morning so that means a early spring & that's good news for sign work ;)
Fig
