Hello Guest it is June 11, 2026, 05:00:32 PM
Author Topic: Kernel speed axis cumulative?  (Read 7662 times)
« on: January 13, 2011, 08:37:22 AM »
Is the kernel speed set in Mach available to each axis at all times, or does the number divide itself amongst the axis' in use during a simultaneous multi axis move?
Re: Kernel speed axis cumulative?
« Reply #1 on: January 13, 2011, 09:21:01 AM »
Its for each axis so if you had 25KHz kernel set and had 6 axis you could pulse at 25KHz to each axis at the same time.
« Reply #2 on: January 13, 2011, 09:54:12 AM »
That is what I suspected.
Thanks very much!
