Hello Guest it is June 11, 2026, 04:46:16 PM
Author Topic: Making a list of things that need fixed in Turn  (Read 32385 times)
Re: Making a list of things that need fixed in Turn
« Reply #20 on: January 05, 2011, 08:36:26 AM »
The way it works now (OK, should work...) you will utilize your whole available speed range in the above example. Do you want to restrict it?? Don't follow you.
« Reply #21 on: January 05, 2011, 08:38:46 AM »
You need a better spindle motor ;)
I will have to read that a few times more  later on when I get some time but from first read is that not exactly what it should do if you have a min and max spindle?
« Reply #22 on: January 05, 2011, 08:51:22 AM »
I wondered how long before you started bragging about your spindle motor.  ;D
But the point is i do not know how it should react.  :(
Phil
« Reply #23 on: January 05, 2011, 09:02:53 AM »
I never bragged, just simply pointed out that yours is a bit of a sub standard spare part  ;D
« Reply #24 on: January 05, 2011, 09:48:51 AM »
AH HA!! found my issue Hood, and Rich........
  I was Using CSS G code generated by my CAM, I swithced to the F/rev and POOF problem when away......
So, I must revise my threading request:
1). Fix CSS?
Rich:  I sent you a PM take a peek.
scott
« Reply #25 on: January 05, 2011, 09:52:33 AM »
Great news Scott :)
« Reply #26 on: January 05, 2011, 04:34:05 PM »
I'm  happy you found the culprit Scott.   :) Another red note placed in the writeup for future update. ;)
You just can't image how much checking went into getting the thread lead right.
Offline DAlgie
  •  314 314
    • Algie Composite Aircraft
« Reply #27 on: January 06, 2011, 10:32:47 PM »
A nice improvement for Turn would be on the Tool page. I use slow feed to move close to the stock or an electronic edgefinder, then switch with jog mode to a 0.001" resolution incremental jog and bump it to touch that way. There is no button on the Tool page so you can switch between continuous jog and incremental jog, so I have to keep switching back and forth between the two pages to set multiple tools. Just a thought.
« Reply #28 on: January 07, 2011, 12:40:45 AM »
Holding down the Ctrl key while using the jog buttons will switch you to incremental mode.
