Hello Guest it is June 12, 2026, 01:43:36 PM
Author Topic: Z AXIS  (Read 7531 times)
Z AXIS
« on: December 02, 2010, 12:08:13 PM »
Hello ALL
 I’m building a CNC router, I’ve  refitted a Denford Orca lathe and a Denford mill with new Boards to run with mach3 the Lathe is up and running so is the mill
 the problem is the router Z axis  stepper motor  Question is dose Mach 3 run the Z axis slower as I can’t get the motor speed up as fast as the X & Y axis’s if so can I override mach 3 when the motor is running sweet it stalls with the light presser
Looking for some help
Many Many Thanks in advance
The Phoenix
  •  9,356 9,356
Re: Z AXIS
« Reply #1 on: December 03, 2010, 02:57:22 AM »
Hi Phoenix,
Welcome to the forum.
Mach will run any or all the axis at the speed you set in motor tuning section for the axis in question (up to the point the motor stalls,of course).
Just for reference, my Z axis is set to run slower than the others, mainly because of the dead weight it carries and the finer pitch leadscrew fitted. Unless you are planning on mulitpass, deep 2.5D work a slower Z should not cause any real increase in program execution times.
Re: Z AXIS
« Reply #2 on: December 04, 2010, 10:34:34 AM »
Hello  Tweakie
Thanks for the help on the Zaxis
 I re checked through the stepper boards and found the VREF motor current was out
Z axis motor running fine now   all I have to do is put it all back together
Thanks again
The Phoenix
  •  9,356 9,356
Re: Z AXIS
« Reply #3 on: December 04, 2010, 11:22:06 AM »
Glad you got it sorted.  :)
