Hello Guest it is June 09, 2026, 10:54:05 PM
Author Topic: Feedrate 300% red  (Read 7983 times)
Feedrate 300% red
« on: November 11, 2010, 10:21:46 AM »
Hi is there any problem if put my machine feedrate 300% red is flashing  when is working I only engraving names 2mm thik silver ? Many Thanks
Re: Feedrate 300% red
« Reply #1 on: November 11, 2010, 10:25:03 AM »
The red LED is flashing so that you know you have the feedrate over ridden, so no problems..
« Reply #2 on: November 11, 2010, 10:26:27 AM »
Just a s a general rule IF you need to make that much adjustment I would reset the feedrates in the Gcode program to the proper level. Then use FRO to make MINOR adjustments.
Just a thought, (;-) TP
« Reply #3 on: November 11, 2010, 10:33:06 AM »
Thanks hood and active member .
