Mach Discussion => General Mach Discussion => Topic started by: kocher on November 11, 2010, 11:21:46 AM
Hi is there any problem if put my machine feedrate 300% red is flashing when is working I only engraving names 2mm thik silver ? Many Thanks
The red LED is flashing so that you know you have the feedrate over ridden, so no problems..
Just a s a general rule IF you need to make that much adjustment I would reset the feedrates in the Gcode program to the proper level. Then use FRO to make MINOR adjustments.
Just a thought, (;-) TP
Thanks hood and active member .
