Hello
Guest
it is
June 09, 2026, 10:53:39 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Feedrate 300% red
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Feedrate 300% red (Read 7982 times)
kocher
21
Feedrate 300% red
on:
November 11, 2010, 10:21:46 AM »
Hi is there any problem if put my machine feedrate 300% red is flashing when is working I only engraving names 2mm thik silver ? Many Thanks
Carnoustie, Scotland
Re: Feedrate 300% red
Reply #1 on:
November 11, 2010, 10:25:03 AM »
The red LED is flashing so that you know you have the feedrate over ridden, so no problems..
BR549
6,965
Reply #2 on:
November 11, 2010, 10:26:27 AM »
Just a s a general rule IF you need to make that much adjustment I would reset the feedrates in the Gcode program to the proper level. Then use FRO to make MINOR adjustments.
Just a thought, (;-) TP
kocher
21
Reply #3 on:
November 11, 2010, 10:33:06 AM »
Thanks hood and active member .
Print
Pages:
1
Go Up
« previous
next »
