Hello Guest it is June 10, 2026, 06:17:32 PM
Author Topic: single axixs wizard  (Read 6797 times)
single axixs wizard
« on: November 04, 2010, 12:12:51 PM »
i need a wizard that will move on a single axixs up and down going a certian length make a mark with a razor blade attach to the bit then move the length and make the mark agian i am wondering if the is already a wizard or if one could be made
Re: single axixs wizard
« Reply #1 on: November 04, 2010, 04:30:37 PM »
I don't know of a wizard. Seems like you are just wanting to dupliate the movement of the Z axis moving  up and down and the X or Y moving a certain distance. You can hand code that or draw what you want and have a program generate the required code.
« Reply #2 on: November 04, 2010, 06:41:40 PM »
If you can come up with a Simple drawing of what you  need it to do and how far each phase has to move I am sure we can come up with something to help out.
DO you have to change the movement values from time to time or does it always stay the same?
